My application is running with the Framework 1.0, Where can I download netadvantage 2007 vol3 CLR 1.0?Thanks
Thanks for the answer. Would you know by any chance if the version 2007 vol1 has the capability to define the excel layout (landscape) when export is used? Or did this capability came on a later release?Thanks
From our Archived Downloads:
Starting with NetAdvantage for .NET 2007 Volume 2, we stopped releasing CLR 1.x versions of our assemblies. For those needing to try out our last release of NetAdvantage for .NET CLR 1.x, you can find that here. Please review our Supported Environments to ensure you understand our support policies for prior versions.
You can go to the archived downloads area to get a version of 2007 Volume 1.
