I am trying to avoid the resize of splitted pane and i use splitterResizeStart and splitterResizeEnd for it. it invokes when i try to resize . but i am not able to use preventDefault() for preventing the resizing
This is my code
this.dockManager?.nativeElement.addEventListener('splitterResizeEnd', ev => { ev.preventDefault(); });
The event details
isTrusted: false bubbles: true cancelBubble: false cancelable: true composed: true currentTarget: igc-dockmanager.dock-workspace.hydrated defaultPrevented: false detail: null eventPhase: 2 path: (28) [igc-dockmanager.dock-workspace.hydrated, app-dock-workspace, div.dockManagerContent, slot, slot, document-fragment, igc-tab-panel-component#tab-panel-1.hydrated, slot, div.content, document-fragment, igc-tabs-component.hydrated, igc-split-pane-component.sc-igc-split-pane-component-h.sc-igc-split-pane-component-s.hydrated, igc-document-host-component.sc-igc-document-host-component-h.sc-igc-document-host-component-s.hydra…, igc-split-pane-component.sc-igc-split-pane-component-h.sc-igc-split-pane-component-s.hydrated, div.pane-container--horizontal, div.pane-container--vertical, document-fragment, igc-dockmanager.doc-manager-geojit-window.hydrated, div.window-tab-container, app-window-tabs, div.dashboard-align, div.light-theme, app-general-dashboard, app-root, body.igx-typography.ng-tns-0-0, html.hydrated, document, Window] returnValue: true srcElement: igc-dockmanager.dock-workspace.hydrated target: igc-dockmanager.dock-workspace.hydrated timeStamp: 33932.199999999255 type: "splitterResizeEnd"
Hi Nikolay,
In order to keep you updated on your request’s status, I have created a private support case with an ID of C-00223359 for you and I will continue assisting you via this support case. In order to view it on our web site please follow these steps:
1) Go to our Customer Portal - https://account.infragistics.com/
2) Log in with your account, if needed
3) From the tab menu select ‘Support’ - https://account.infragistics.com/support-cases
There you will find a list with all the active cases.
Please let me know if you have any additional questions regarding this matter.
Best regards, Bozhidara Pachilova
Hi Bozhidara Pachilova,
Which version of infragistics can expect this feature?
The request has been logged and will be reviewed by the team as soon as possible. I will keep you posted on the progress. Thank you for your patience.
Best regards,
Bozhidara Pachilova
Thank You Bozhidara Pachilova
I am waiting for your response
Hello Nikolay,
Thank you for posting to Infragistics Community!
I was able to reproduce this behavior and after reviewing this with the development team, a discussion around the possibility to cancel the splitterResizeStart event has been initiated. Please, note that it will make more sense to cancel the ‘Start’ event rather than the ‘End’ one. In any case, currently, it seems that canceling either of them has not been implemented yet, so the team will look into it.
I will keep you posted as soon as there is new information on the matter.
Thank you for your cooperation.
