HiI've been looking for the option Feature Chooser in igTreeGrid documentation, but I couldn't find. Someone can tell me if this option is available in igTreegGrid ?Thanks
Thank you for the update. After some more research that property has more to do with if the icon should display in a touch/mobile environment. To enable the feature chooser you have to enable two or more features that would require it such as advanced filtering, multiple sorting, and column moving. Single sorting and basic filtering do not enable the feature chooser because they can be displayed in a way that doesn’t require it.
Thanks for the answer.I added the option and continued the same way.
Here is a codepen to verify that the addition of the option featureChooserIconDisplay: "always" , doesn't add the icon.
http://codepen.io/anon/pen/gwrPbG
Thank you
Hello Paulo,
You can manually enable the feature chooser by setting the featureChooserIconDisplay property:
http://www.igniteui.com/help/api/2016.1/ui.igtreegrid#options:featureChooserIconDisplay
Please let me know if you have any further questions concerning this matter.
