195
Row Edit Dialog
I'm using the last version of Ignite UI and I have 2 questions about the grid. I use the ASP.net MVC helper but I think it's the same questions without ASP.NET.
1) I have a lot of columns and I would like to see some solumns only in the "Row edit dialog" and not in the grid. If I set Hidden property, the columns are hidden in the grid but also in the "Row edit dialog". Is there a way to hidden the column only in the grid ?
2) In my "Row edit dialog", I would like to customize some fields, I tested the following example:
<script id="dialogTemplate" type="text/html">
<div style="float: left;">
<table style="width: 100%;">
<colgroup>
<col style="width: 30%;" />
<col style="width: 70%;" />
</colgroup>
<tbody data-render-tmpl="true"></tbody>
</table>
</div>
</script>
<script id="editorsTemplate" type="text/html">
<tr>
<td style="text-align:right;color:#777;"><strong>${headerText}</strong></td>
<td>
{{if ${key} == 'MethodDescription'}}
<textarea data-editor-for-${key}="true" rows="5" />
{{else}}
<input data-editor-for-${key}="true" />
{{/if}}
</td>
</tr>
</script>
But the textarea field stays with a heigh of 1 row. How can I do to have 5 rows (or maybe other feature) ?
If I remove the data-editor-for-${key}="true" , I haven't the value of the filed in the textarea.
Alain
Parents
  • 12480
    Hi Alain,
    You can show the hidden columns in the row edit dialog by using the showEditorsForHiddenColumns option within rowEditDialogOptions. You can see a working example in this fiddle:
    http://jsfiddle.net/d4p34p0f/
    I am currently looking into how you can customize the the height of the text area editor.
Reply Children
No Data
