I'm using an ASP.Net MVC igGrid and i have created the grid like below
@(Html.Infragistics().Grid(this.Model.lstMilestoneDetails).PrimaryKey("intMileStoneNo").AutoCommit(false).AutoGenerateColumns(false).ID("MileStoneGrid").Columns(column => { column.For(x => x.intMileStoneNo).Hidden(true); //MilestoneNo column.For(x => x.txtDescription).HeaderText("Description"); //Description column.For(x => x.dtDate).Format("dd-MMM-yyyy").HeaderText("Date").Width("15%"); column.For(x => x.fltPercentage).HeaderText("Percentage"); //Percentage column.For(x => x.fltAmount).HeaderText("Amount"); //Amount column.For(x => x.MilestonePercentage).HeaderText("Milestone%"); }).Features(features => { features.Updating().ColumnSettings(cs => { cs.ColumnSetting().ColumnKey("txtDescription").EditorType(ColumnEditorType.Text).Required(true); cs.ColumnSetting().ColumnKey("dtDate").EditorType(ColumnEditorType.DatePicker).Required(true); cs.ColumnSetting().ColumnKey("fltPercentage").EditorType(ColumnEditorType.Numeric).DefaultValue(0).Required(true).NumericEditorOptions(opts => opts.MaxValue(100).MinValue(0)); cs.ColumnSetting().ColumnKey("fltAmount").EditorType(ColumnEditorType.Numeric).DefaultValue(0).Required(true); cs.ColumnSetting().ColumnKey("MilestonePercentage").ReadOnly(true); }); features.Summaries().ColumnSettings(cs => { cs.ColumnSetting().ColumnKey("fltPercentage").AllowSummaries(true).SummaryOperands(so => { so.SummaryOperand().RowDisplayLabel("Sum").Type(SummaryFunction.Sum).Active(true); }); cs.ColumnSetting().ColumnKey("fltAmount").AllowSummaries(true).SummaryOperands(so => { so.SummaryOperand().RowDisplayLabel("Sum").Type(SummaryFunction.Sum).Active(true); }); }); features.Resizing(); features.ColumnMoving().AddMovingDropdown(false); features.Sorting().ApplyColumnCss(false); features.Selection().MultipleSelection(true); features.RowSelectors().EnableSelectAllForPaging(true).EnableCheckBoxes(true).EnableRowNumbering(false); features.Paging().PageSize(5).PageSizeDropDownLocation("inpager").AddClientEvent("pageIndexChanged", "fnPagination").AddClientEvent("pageSizeChanged", "fnPageSizeChange"); }) .AutoCommit(true) .DataBind().Render() )
I want to calculate a value of cell "Amount" when I change value of "Percentage" and vice versa . I need to change the values either on blur of that particular cell or when the value is changed.
Like When i enter percentage as 15% i want to update the amount value like 15 * some predefined value.
How can I do that? Can you kindly provide it with an example?
Hello Kumar,
I am glad that you find my suggestion helpful!
My suggestion is to handle igNumericEditor`s valueChanged event. In this event the value of the other depended editor can be set according to your formula. For example:
1) Define the valueChanged event in Updating column settings collection:
.Features(f => { f.Updating() .EnableAddRow(false) .EditMode(GridEditMode.Row) .ColumnSettings(cs => { cs.ColumnSetting().ColumnKey("Id").ReadOnly(true); cs.ColumnSetting().ColumnKey("Amount").NumericEditorOptions(opts=> { opts.AddClientEvent("valueChanged", "amountValChanged"); }); cs.ColumnSetting().ColumnKey("Percentage").NumericEditorOptions(opts => { opts.AddClientEvent("valueChanged", "percentageValChanged"); }); }); })
2) Handle valued in valueChanged event hadnlers:
<script> $(function () { window.amountValChanged = function(evt, ui) { $("#grid").igGridUpdating("editorForKey", "Percentage").igNumericEditor("value", ui.newValue * 2); } window.percentageValChanged = function (evt, ui) { $("#grid").igGridUpdating("editorForKey", "Amount").igNumericEditor("value", ui.newValue / 2); } }); </script>
Please test this suggestion on your side and let me know if you have any additional questions afterwards.
Hi Vasya,
Thanks for the reply.
I need the above requirement for the "row" editMode. Can you please provide an example for that as well.
Kumar G
Thank you foe getting back to me.
What I can suggest for having the vice versa dependency of these cells is handling editCellEnding event of the Updating feature. In this event you can check which is the cell that triggered it and if it as any of the Amount or Perecntage cells to update the other one accordingly using setCellValue method. For example:
$(document).delegate("#grid", "iggridupdatingeditcellending", function (evt, ui) { if (ui.columnKey === "Amount") { var value = ui.value * 2; //make your calculcations here $("#grid").igGridUpdating("setCellValue", ui.rowID, "Percentage", value);
} if (ui.columnKey === "Percentage") { var value = ui.value / 2; //make your own calculations here $("#grid").igGridUpdating("setCellValue", ui.rowID, "Amount", value); } });
Please keep in mind that this approach will work as expected for editMode set to "cell". If you have a requirement for "row" editMode please let me know.
Regards,Vasya KacheshmarovaAssociate Software DeveloperInfragistics
Thanks for the reply. This solution works when i change the percentage,the amount gets calculated correctly.
But how can i try the vice versa of it. When i tried adding another formatter function for percentage..it goes in a loop and the values are coming out wrong.
When i have two formatter function each for Amount and Percentage like below example
Eg: Old Percentage :25 Amount:(25(percent)*5000(predefined value)) * 100 = 1250
New Percentage : 50 Amount--> (50 * 5000) *100 =2500
When i change the amount to 4000 then it picks the old percentage instead of the updated percentage for calculation.and the values are coming out wrong.
How can i get the new updated value to perform the vice versa.
