I'm using WebUpload and a WebDataMenu in the same page, but there are problems with WebDataMenu. I Can't navigate and there are errors:
I think is something to do with the references, or maybe I'm doing something wrong.
Please, I need this urgent.
Thanks in advance.
This will be fixed in the next Service Release. A workaround for this issue is given here: http://community.infragistics.com/forums/p/57778/294493.aspx#294493
I removed the WebUpload but the problems continue, and when I removed the reference to ig.ui.min.js the problems ceased.
I tried to add a reference to ig.ui.upload.min.js but the problems appeared again and without one of this references the webupload can't work.
I attached a rar with a single page, the references to scripts and stylesheets were added automatically when I drag the webupload to the page.
I'm using version 11.1.
Thanks in advance for the help, please this is very urgent.
Hi Alejandro,
First my advice is just remove WebUpload from the page and check whether WebDataMenu is working. If not then you should check references. Here is link for WebDataMenu samples http://samples.infragistics.com/aspnet/ComponentOverview.aspx?cn=data-menu
If the problem occurs then could you send us some example(some little one just to check it and test)- this will be very helpful for us to investigate the problem.
Regards,Miro Hristov
