160
Keep extra metadata in the igDatasource being bound to a grid without adding hidden columns
We are trying to use the igDatasource with the igGrid which works fine however if we have extra metadata in the json being passed down from the server, the igDatasource and igGrid seem to remove it. Not from the orginal data being used to create the datasource but just in the igDatasource or igGrid. For instance we have a grid with 14 columns and then three hidden values not in columns. These three values are used to contact the database for deletion, updates, or used in a double click events to display a record represented by a row. We could use the selectedrow  to get the currently selected row index and use the intial results to pull up those values but this is not ideal when we have sorting enabled because the grid’s row indexes no longer match the orginal datasource’s indexes used to create the igDatasource. Based on the issues we had with columns being hidden and the grid’s width set to a percentage we would rather not use hidden columns to achieve this at this point in time (http://forums.infragistics.com/forums/t/68397.aspx). I have attached a sample of the JSON being passed from the server to the page using an ajax request. The values we are refering to are prefixed with an underscore (_deleteID, _objectID, and _classID)
Joshua
    "d": {
        "columns": [
                "key": "1234",
                "headerText": "ID",
                "width": "100px",
                "dataType": "number",
                "format": "int"
                "key": "1235",
                "headerText": "Alpha25",
                "width": "200px",
                "dataType": "string",
                "format": ""
                "key": "1236",
                "headerText": "UniqueKey",
                "width": "200px",
                "format": ""
                "key": "1237",
                "headerText": "Bool",
                "width": "100px",
                "dataType": "bool",
                "format": ""
                "key": "1238",
                "headerText": "FormattedText",
                "width": "250px",
                "format": ""
                "key": "1239",
                "headerText": "Currency",
                "width": "100px",
                "format": "currency"
                "key": "1240",
                "headerText": "objectID",
                "width": "100px",
                "format": "int"
                "key": "1241",
                "headerText": "objectName",
                "width": "250px",
                "format": ""
                "key": "1242",
                "headerText": "createdBy",
                "width": "240px",
                "format": ""
                "key": "1243",
                "headerText": "createdDate",
                "width": "180px",
                "dataType": "date",
                "format": "dateTime"
                "key": "1244",
                "headerText": "revisionDate",
                "width": "180px",
                "dataType": "date",
                "key": "1245",
                "headerText": "revisionBy",
                "width": "240px",
                "format": ""
                "key": "1246",
                "headerText": "className",
                "width": "250px",
                "format": ""
                "key": "1248",
                "headerText": "Null",
                "width": "100px",
        "schema": {
            "fields": [
                    "name": "1234",
                    "type": "number"
                    "name": "1235",
                    "type": "string"
                    "name": "1236",
                    "type": "string"
                    "name": "1237",
                    "type": "bool"
                    "name": "1238",
                    "type": "string"
                    "name": "1239",
                    "type": "number"
                    "name": "1240",
                    "type": "number"
                    "name": "1241",
                    "type": "string"
                    "name": "1242",
                    "type": "string"
                    "name": "1243",
                    "type": "date"
                    "name": "1244",
                    "type": "date"
                    "name": "1245",
                    "type": "string"
                    "name": "1246",
                    "type": "string"
                    "name": "1248",
                    "type": "number"
            "searchField": "d"
        "results": [
                "1234": 354,
                "1235": "CHRYSANTHEMUM",
                "1236": "355",
                "1237": false,
                "1238": "",
                "1239": null,
                "1240": 1117,
                "1241": "",
                "1242": "MANAGER",
                "1243": "/Date(1331847285000)/",
                "1244": "/Date(1336427698000)/",
                "1245": "MANAGER",
                "1246": "ExtendedClassExt",
                "1248": null,
                "_deleteID": "1117",
                "_objectID": "1117",
                "_classID": 1001
                "1234": 355,
                "1236": "356",
                "1237": false,
                "1238": "",
                "1239": null,
                "1240": 1118,
                "1241": "",
                "1242": "MANAGER",
                "1243": "/Date(1331847518000)/",
                "1244": "/Date(1336427725000)/",
                "1245": "MANAGER",
                "1248": null,
                "_deleteID": "1118",
                "_objectID": "1118",
                "_classID": 1001
Parents
No Data
Reply
  • 24671
    Suggested Answer
    hi Joshua,
    i believe what happens is that those get removed because they aren't mapped to colmuns and localSchemaTransform is set to true. I would suggest setting localSchemaTransform to true and see if that works.
    Hope that helps. Thanks
    Angel
Children
No Data
