Hi, I just installe the trial version of jQuery (NetAdvantage_jQuery_20121.msi). I am not able to install the samples installer, but in any case, how can I get a sample of using a igGrid? I am talking about getting a "complete VS project", not some parts of code. Also, is NetAdventage 2012.1 compatible with VS2008?
Thanks.
Fernando
Hi Fernando,The problem you've encountered with the Samples Browser installation is most probably caused by the fact that you might not have ASP.NET 3 installed.If that's the case, you should get it from: http://www.asp.net/mvc/mvc3 However, I'm afraid that the Samples Browser has been developed as a Visual Studio 2010 solution and I don't think Microsoft support backwards compatibility/conversion to Visual Studio 2008.However (again), you can easily install an express version of Visual Studio 2010 so you can open and use the installed Samples Browser.
fpardo said:Also, is NetAdventage 2012.1 compatible with VS2008?
