I am using a igHierarchalGrid. I can expand the child grids to display when using
dataSourceType: "json", dataSource: jsonData,
Supplying the json for the main grid and child grids together in jsonData.
But when changing to a remote URL as the data source supplying the exact same json
dataSourceType: "remoteUrl", dataSource: URL,
The main grid is displayed OK but I receive the error when trying to expand the child grid:
'The remote request to fetch data has failed:'
It looks as though the grid is trying to go to the remote URL again although the data for the child grid should be already there.
Can anyone explain how to get the child grid to expand without trying to invoke the URL
Hello ecanate,
Please let me know if you have further questions.
Hello ecatenate,
My apologies for the delay of my response.
I was not very sucessful in reproducing the behavior you have described. I attached a sample I was working on.
Please let me know if it demonstrates the behavior you seek or otherwise.
If you have any questions, please let me know as well.
Thank you for your patience while I was working on this issue.
I am able to reproduce the behavior you have described.
I will be updating you with more details by tomorrow.
If you have any questions, please let us know as well.
Thanks for your reply to the problem.
We have resolved by removing the reference to dataSourceType in
dataSource: URL,
This doesnt cause problem in igGrid but igHierarchicalGrid produces remote fetch error when expanding the child grid - even though oData is false and load on demand should be disabled for jquery widget.
In addition, I also recommend using .DataSourceURL with the following additional function above the grid's definition:
<script type="text/javascript"> $(function () { $("#igGrid1").live("iggriddatabinding", function (evt, ui) { $("#igGrid1").igGrid("option", "dataSourceType", "json"); }); }); </script>
For more information, please refer to the following forum thread:
http://ko.infragistics.com/community/forums/p/68393/347096.aspx
I hope this helps.
