2745
Programmatically set an editor as required based on selection changed event
I have an igGrid and on the edit cell starting event I am hooking into the SelectionChanged event of an igCombo control of one of the columns.  Based on the value that the user selects, I need to require a field in the grid.  That being said, here's the code:
$("#ItemsGrid").on("iggridupdatingeditcellstarting", function (e, ui) {
    var row = $("#ItemsGrid").igGrid("findRecordByKey", ui.rowID);
    if (ui.columnKey === 'Description') {
        $(ui.editor).igCombo("option", "dataSource", row.Descriptions);
        $(ui.editor).igCombo("option", "dataBind");
        $(ui.editor).on("igcomboselectionchanged", function (e, list) {
            $.each(row.Descriptions, function () {
                if (this.Description === row.Description) {
                    var editorCuft = $("#ItemsGrid").igGridUpdating("editorForKey", "Cuft");
                    var editorDensity = $("#ItemsGrid").igGridUpdating("editorForKey", "Density");
                    var isCuftRequired = editorCuft.igTextEditor("option", "required");
                    var isDensityRequired = editorDensity.igTextEditor("option", "required");
                    return false;
        return row.Descriptions.length != 1; // No editing for entries that contain one single option
The problem I am having is that isCuftRequired is not returning the expected bool value but rather the editor itself. I've tried the following:
$(editorCuft).igTextEditor("option", "required");
In theory I'd should be able to set the value and have the UI reflect the change if the user decides not to enter a value. For example:
$(editorCuft).igTextEditor("option", "required", this.RequiresCuft);
$(editorDensity).igTextEditor("option", "required", this.RequiresDensity);
But I cannot hook into the correct object to do so.
Thoughts?
  • 2745
    Verified Answer
    I don't like the solution but this does work:
    var editorCuft = $("#ItemsGrid").data("igGridUpdating").editorForKey("Cuft");
    editorCuft.data("igEditor").options.required = true;
    editorCuft.igEditor("option", "validatorOptions", { required: true, onsubmit: true, onblur: true });
    The API should be able to let me set this through methods but it isn't working. This does work, but I fear it may have reprecussions. Until I have a true solution, this workaround will have to do.
