In the 2012.2 release there was a zip file of the debug versions of the JavaScript code installed into "C:\Program Files\Infragistics\IgniteUI 2012.2" named infragistics.IgniteUI.debug.zip
The 2013.1 release doesn't install this file. Is it available to download anywhere?
Mark
Hello Mark,
Thank you for your followup.
Glad that the issue has been resolved. Please feel free to contact us if you have any further questions regarding this matter.
Hi Alex,
I used the NetAdvantage 2013 Vol. 1 Platform Installer. I didn't change any of the install options. I did install the help & samples.
I used your suggestion and installed on a virtual machine. The infragistics.IgniteUI.debug.zip was installed on the virtual and I have now copied this to my main development machine.
Thanks for your help.
The file should be there by default.
Can you specify what kind of installer you used (platform installer, MSI package or No Installer package) and did you changed some of the install options?
Also do you install help and samples too or only the product?
If you have some empty virtual machine you can download Platform Installer (it is small in size) and run in this machine. It will download all needed files and install them on this machine. Then you can check the same directory again and see if the file is present there.
I am looking forward to hearing from you.
I've done a complete search of my hard drive but cannot find the file "infragistics.IgniteUI.debug.zip" anywhere.
I too am running Windows 7 x64.
I have checked the installation on my machine (Windows 7 x64) and I am able to see this file in “C:\Program Files (x86)\Infragistics\IgniteUI 2013.1” directory.
It is named “infragistics.IgniteUI.debug.zip” and contains un-minified versions of our scripts.
You can search for this file in above location or if your installation is placed in different location you can search for it there.
Let me know if you were able to find it.
