40
igCombo release bug
I have an aplication made with MVC4, with a igCombo that call a function in the event "iggridupdatingeditrowended".
The aplication is finished, and the igCombo works great in debug mode, but the event is never called in release mode.
Any suggestions?
Thanks in advise
  • 4315
    Hi, David.
    Thank you for using our control and I hope that I will be able to help you.
    I guess you have Grid control that is using Combo as editor - sample similar to that one Editing Combo Editor. I used the same sample and just added the following code:
    $(window).on("iggridupdatingeditrowended", "#grid1", function (evt, ui) {
        console.log(ui.rowID);
    The event is fired when I press the "DONE" button in both debug and release modes.
    You can check this and if again it doesn't work for you case, if it is possible for you, please attach me a sample with your scenario. I will wait for your feedback.
    Best regards,
    Nikolay Alipiev
