595
Setting the regional value in the loader causes an exception on load
I noticed the dates on the igGrid were showing the US date format (MM/DD/YYYY) instead of the UK date format (DD/MM/YYYY).
I tried to set the regional value in the loader to 'en-GB' as follows:
$.ig.loader({
    scriptPath: 'ig_res/igniteUI/js/',
    cssPath: 'ig_res/igniteUI/css/',
    regional: 'en-GB',
    resources: 'igGrid.*,igShared,igEditors,igValidator,extensions/infragistics.ui.editors.knockout-extensions.js,extensions/infragistics.datasource.knockoutjs.js,extensions/infragistics.ui.grid.knockout-extensions.js',
But I get the following error every time on load:
0x800a138f - JavaScript runtime error: Unable to get property 'extend' of undefined or null reference
If I remove the regional override, then the exception doesn't appear. Also, if I use the autoDetectLocale property and set it to true, then the dates are still in the wrong format, despite my machine being set to the en-GB culture.
