I want to implement tree control of infragistics, but when I am trying to implement by bellow script
<script src="@Url.Content("~/Scripts/ig/modules/infragistics.ui.tree.js")" type="text/javascript"></script>
<script src="@Url.Content("~/Scripts/ig/modules/infragistics.ui.shared.js")" type="text/javascript"></script>
<script src="@Url.Content("~/Scripts/ig/modules/infragistics.util.js")" type="text/javascript"></script>
<script src="@Url.Content("~/Scripts/ig/modules/infragistics.templating.js")" type="text/javascript"></script>
<script src="@Url.Content("~/Scripts/ig/modules/infragistics.datasource.js")" type="text/javascript"></script>
In the mvc page but not going to work, so I have to mention bellow code in page but the performance of my application is going down.
<script src="@Url.Content("~/Scripts/ig/infragistics.core.js")" type="text/javascript"></script>
<script src="@Url.Content("~/Scripts/ig/infragistics.lob.js")" type="text/javascript"></script>
Is there any way to load only tree control in the page which perfume faster.
Hello sushant,
Please note that to work with IgniteUI controls, you should reference the needed resources correctly. If you choose to reference these resources manually, then please keep in mind their count and order. For more information of how to manage the required resources please refer to the following article:
http://help.infragistics.com/Help/Doc/jQuery/2013.1/CLR4.0/html/Deployment_Guide_JavaScript_Resources.html
The necessary resources for a particular control could be found at: http://help.infragistics.com/Help/Doc/jQuery/2013.1/CLR4.0/html/Deployment_Guide_JavaScript_Files.html#igTree
Please note that infragistics.core.js and infragistics.lob.js are combined scripts and if you're referencing your scripts manually for the igTree, then there's no need to add them. Essentially they contain all other scripts in themselves, so you could reference either only them or only all other needed resources.
If you have any further questions, feel free to contact me.
Sincerely,
Tsanna
