The header row is appearing narrower than the rest of the grid (see attached image). It acts the same in IE11, Firefox 32, and Chrome 37.
I am using an igGrid inside a tile using the tileLayoutManager. It isn't overly complicated, but I am apparently messing it up somehow...am I missing an option?
<div id='tileChartGrid1'></div>
var aoData = [{"Name":"Availability","Value":1147.4},{"Name":"Operating","Value":122.7},{"Name":"Mechanical","Value":0},{"Name":"Electrical","Value":0},{"Name":"Automation","Value":5.6},{"Name":"Upstream / Scheduling","Value":0.0},{"Name":"Finishing","Value":164.3},{"Name":"Shipping","Value":0},{"Name":"Quality","Value":0}];
$('#tileChartGrid1').igGrid({height: "100%", autoGenerateColumns: false, datasource: aoData, columns: [{ headerText: "Name", key: "Name", dataType: "string" },{ headerText: "Value", key: "Value", dataType: "number" }]});
Looking at it thru developer tools reveals a couple of things (see attached screen shots) I can see that the div it creates to contain the header has "overflow: hidden" as an inline style. If I disable that, then the header appears properly, but often the columns do not align with the columns in the rest of the grid.
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hello rsimm,
Thank you for contacting Infragistics Developer Support!
I have tried to reproduce your issue using your code, but without any success.Could you please modify the attached sample so the issue can reproduce.
Thanks!
