250
Do not want to show upload progress bar
HI,
I am using infragistics file upload, but i do not want to show the progress bar. I tries using clearAll, at the time of fileUploaded event is  called, but it is also not clearing the upload bar. It clears, when user select another file to upload. The upload bar is unnecessarily taking some space in UI.
What i need is when user select file to upload, the data is added to grid, but instead of progress information, a dialog box saying file data is uploaded to grid can be shown, which will be more simpler. How can i achieve it?
  • 23953
    Verified Answer
    Hello Vivek,
    You can hide the progress bar using CSS. For example if your igUpload has an ID of "up1" then the CSS should be:
    <style>
    #up1 .ui-igupload-progress-container, #up1 .ui-igupload-container
    display: none;
    #up1 div.ui-widget-content
    border: 0px;
    </style>
    You may also want to change the "Add" button label to "Upload File" by setting the "labelAddButton: 'Upload File'".
    I'm attaching a sample for your reference.
    Hope this helps,
    Martin Pavlov
    Infragistics, Inc.
    igUpload_hide_progressbar.zip
