I am trying to enable 2 Way DataBinding and CRUD operations. So far I only have the "Update" working, the "Add" failes to save (I haven't tested delete). The culprit seems to be the fact that I am unable to get the BaseTableName to "stick" in the Designer for the Band Properties. As soon as I Save it and then go back in, it is gone. I am under the "Edit Data Structure" -> "Bands and Columns" and I have the (only) Band selected. I have also tried prefixing the table name with "dbo." it still won't take it. As soon as I click the "Save" button (which is just a "submit" button, right?) the new row goes away. (Any row/field changes work great..)
I have also tried adding the "BaseTableName" to the asp code and still the Add doesn't work.
Any ideas?
The two way autobind is actually "codeless" (you are probably thinking of older versions of WebGrid).
(Rumen, the Infragistics Employee that posted in my "other" thread" summed it up well:
In two-way databinding (automaticallly updating the database), you will typically also need to have BaseTableName defined as well. For example:
<igtbl:UltraGridBand DataKeyField="CustomerID" BaseTableName="Customers">
Also, if you are using AccessDataSource, SqlDataSuorce, etc, make sure you generate the CRUD commands in design time by clicking the Advanced button and the selecting "Generate CRUD..." )
This is exaclty what I was testing. (I have a new programmer fresh from college and I am basically trying to give him some assignments and I am looking for some RAD tools so we can get some prototypes up asap. (Just to give you some background.)
I didn't put any "code" in for the delete or the change and they work. :)
shaynejud said:No matter what I do the "BaseTableName" doesn't save.
I don't see any code that would add new records to the underlying database. You might find this Knowledge Base article helpful:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=9966
As I said in reply to your other post (http://forums.infragistics.com/forums/p/11931/51394.aspx#51394), I don't think it has anything to do with BaseTableName.
I'm probably missing something, but I don't see anything in your code that would save the record. I assume you're handling the UpdateRow event, but you don't show us that code.
There's more info on using .UpdateRow in this KB article: http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=9966
Here is my code.
I have tired SQL datasources and Access Datasources. No matter what I do the "BaseTableName" doesn't save. I can put it in the markup, but it still wont add records. (It will save and delete records from the grid, with or without the "BaseTableName" in the markup!)
<asp:SqlDataSource ID="SqlDataSource1" runat="server"
ConflictDetection="CompareAllValues"
ConnectionString="<%$ ConnectionStrings:ShayneInfragisticsTestConnectionString %>"
DeleteCommand="DELETE FROM [Orders] WHERE [ID] = @original_ID AND [OrderNum] = @original_OrderNum AND [OrderDescription] = @original_OrderDescription AND [Total] = @original_Total"
InsertCommand="INSERT INTO [Orders] ([OrderNum], [OrderDescription], [Total]) VALUES (@OrderNum, @OrderDescription, @Total)"
OldValuesParameterFormatString="original_{0}"
SelectCommand="SELECT * FROM [Orders]"
UpdateCommand="UPDATE [Orders] SET [OrderNum] = @OrderNum, [OrderDescription] = @OrderDescription, [Total] = @Total WHERE [ID] = @original_ID AND [OrderNum] = @original_OrderNum AND [OrderDescription] = @original_OrderDescription AND [Total] = @original_Total">
<DeleteParameters>
<asp:Parameter Name="original_ID" Type="Int32" />
<asp:Parameter Name="original_OrderNum" Type="String" />
<asp:Parameter Name="original_OrderDescription" Type="String" />
<asp:Parameter Name="original_Total" Type="Decimal" />
</DeleteParameters>
<UpdateParameters>
<asp:Parameter Name="OrderNum" Type="String" />
<asp:Parameter Name="OrderDescription" Type="String" />
<asp:Parameter Name="Total" Type="Decimal" />
</UpdateParameters>
<InsertParameters>
</InsertParameters>
</asp:SqlDataSource>
<igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Browser="Xml"
DataKeyField="ID" DataSourceID="SqlDataSource1" Height="211px" Width="497px">
<bands>
<igtbl:UltraGridBand AllowAdd="Yes" AllowDelete="Yes" AllowUpdate="Yes"
DataKeyField="ID" BaseTableName="Orders">
<Columns>
<igtbl:UltraGridColumn BaseColumnName="ID" DataType="System.Int32"
IsBound="True" Key="ID">
<Header Caption="ID">
</Header>
</igtbl:UltraGridColumn>
<igtbl:UltraGridColumn BaseColumnName="OrderNum" IsBound="True" Key="OrderNum">
<Header Caption="OrderNum">
<RowLayoutColumnInfo OriginX="1" />
<Footer>
</Footer>
<igtbl:UltraGridColumn BaseColumnName="OrderDescription" IsBound="True"
Key="OrderDescription">
<Header Caption="OrderDescription">
<RowLayoutColumnInfo OriginX="2" />
<igtbl:UltraGridColumn BaseColumnName="Total" DataType="System.Decimal"
IsBound="True" Key="Total">
<Header Caption="Total">
<RowLayoutColumnInfo OriginX="3" />
</Columns>
<addnewrow view="NotSet" visible="NotSet">
</addnewrow>
</igtbl:UltraGridBand>
</bands>
<displaylayout allowaddnewdefault="Yes" allowcolsizingdefault="Free"
allowcolumnmovingdefault="OnServer" allowdeletedefault="Yes"
allowsortingdefault="OnClient" allowupdatedefault="Yes"
bordercollapsedefault="Separate" headerclickactiondefault="SortMulti"
loadondemand="Xml" name="UltraWebGrid1" rowheightdefault="20px"
rowselectorsdefault="No" selecttyperowdefault="Extended"
stationarymargins="Header" stationarymarginsoutlookgroupby="True"
tablelayout="Fixed" version="4.00" viewtype="OutlookGroupBy">
<framestyle backcolor="Window" bordercolor="InactiveCaption"
borderstyle="Solid" borderwidth="1px" font-names="Microsoft Sans Serif"
font-size="8.25pt" height="211px" width="497px">
</framestyle>
<pager minimumpagesfordisplay="2">
<PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
<borderdetails colorleft="White" colortop="White" widthleft="1px"
widthtop="1px" />
</PagerStyle>
</pager>
<editcellstyledefault borderstyle="None" borderwidth="0px">
</editcellstyledefault>
<footerstyledefault backcolor="LightGray" borderstyle="Solid" borderwidth="1px">
</footerstyledefault>
<headerstyledefault backcolor="LightGray" borderstyle="Solid"
horizontalalign="Left">
</headerstyledefault>
<rowstyledefault backcolor="Window" bordercolor="Silver" borderstyle="Solid"
borderwidth="1px" font-names="Microsoft Sans Serif" font-size="8.25pt">
<padding left="3px" />
<borderdetails colorleft="Window" colortop="Window" />
</rowstyledefault>
<groupbyrowstyledefault backcolor="Control" bordercolor="Window">
</groupbyrowstyledefault>
<groupbybox>
<boxstyle backcolor="ActiveBorder" bordercolor="Window">
</boxstyle>
</groupbybox>
<addnewbox hidden="False">
<boxstyle backcolor="Window" bordercolor="InactiveCaption" borderstyle="Solid"
borderwidth="1px">
</addnewbox>
<activationobject bordercolor="" borderwidth="">
</activationobject>
<filteroptionsdefault>
<filterdropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid"
borderwidth="1px" customrules="overflow:auto;"
font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px" height="300px"
width="200px">
<padding left="2px" />
</filterdropdownstyle>
<filterhighlightrowstyle backcolor="#151C55" forecolor="White">
</filterhighlightrowstyle>
<filteroperanddropdownstyle backcolor="White" bordercolor="Silver"
borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;"
font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px">
</filteroperanddropdownstyle>
</filteroptionsdefault>
</displaylayout>
</igtbl:UltraWebGrid>
<asp:Button ID="Button1" runat="server" Text="Save" />
</form>
Without looking at your code and your markup, I don't think anyone is going to be able to guess what's causing your problem.
If you post your code and markup, I'll look at it. (Somebody who knows more than I do may also look at it. ;-)
