Do you have some examples on how to create custom summary operands for the XamWebGrid. I've searched the website and the documentation, but I did not find any actual examples...
Arjen
You would add it to the respective columns summary operands collection.
grid.Columns.DataColumns[0].SummaryColumnSettings.SummaryOperands
How do you bind or attach it with the grid when the columns are generated during runtime ?
can you provide some sample code ?
I found it after walking through your source code. For others with the same question:
Create a class which derives from SynchronousSummaryCalculator with an override for Summarize (here's your summary logic). Create a class which derives from SummaryOperandBase which returns the previous SynchronousSummaryCalculator using the SummaryCalculator property.
