I'm having a problem with my content links when the navigation pane is minimized. The project path is not included in the url. ie: /views/today.xaml is read from the root of my host rather than the root of the project.
Any ideas?
Lisa.
I've converted my hyperlinks to buttons, works great.
Thanks!
Hi Lisa,You can use Infragistics v.9.2, just remove 10.1 references, add references to the 9.2 and replace v.10.1 with 9.2 in the XAML. I'm attaching updated sample.There is nothing specific in the Button, I use the MS System.Windows.Controls.Button in the OutlookBar group. I see that your code uses a style but it probably it targets HyperlinkButton <Button x:Name="ButtOpportunities" Style="{StaticResource NavLinkB}">Try without any additional settings, use something like this<Button Content="Today" Click="Button_Click"/>Regards,Marin
Also one thing I noticed looking through your code is that you call a Click property in your Button control (Click="Button_Click_1") I don't have access to this property, is this something new in V.10? This might explain why my click event does not fire on the button.
Hi Marin
Thanks for this but unfortunately this project is using infragistic v.10.1, I'm using v.9.2, we have not upgraded to v10 so I do not have the reference libraries installed and therefore cannot test this. Also it still may not work in v9.2
Lisa
Hi Lisa,It should work. I created a small sample to reproduce the issue.Could you check this solution (Navigate.zip) if it works for you?Regards,Marin
