Hi;
Couple of new questions:
a) For the WP7 version, will you be covering QR code as of next release? It's the code that we will be using.
b) On the SL version, can you also offer a method that we can turn the barcode to a JPEG or PNG and allow the user to save it for their use?
c) Is the generated barcode on the screen, a vector graphic? Meaning, can we make a large size without loosing quality and then save it as image? For example a QR Code size of 8 1/2 x 11 page?
Thank you in advance!
Thank you Petia;
Feature requested was entered.
Hi Ben,Directly onto your questions:a) yes, it's in the list and we are working on it.b) you can set a request feature from here.c) you will not lose any quality as resizing any of the barcode symbologies the way you need them. Regarding the size of every symbology compared to its container (not only the matrix size) you could use also some of the properties, described at:http://help.infragistics.com/NetAdvantage/DV/2010.3/CLR4.0/?page=xamBarcode_Settings.html
No problem. BTW, for the WP7, we're only interested to read/decode it and not generate it like in SL.
Thanks!
That's my mistake. I read it as "WPF". I'll forward your question.
If you read my (a) question, I asked if the QR Code is covered in WP7 Phone version and not the desktop. I see the desktop version.
