183
problem with updating webgrid from custom form.
 hey.
i've created an heirarchical webgrid which  holds two bands of data created at runtime
[nothing is defined at design, but the webgrid and it's visual appearance, colors, and such, rows and columns are not defined]
 a dataset is created at runtime during page load event with sqldataadapter.
when i click on child row a new modal window appears  with a custom form to update the data of the selected row, the reason i'm using a custom form is since i'm updating data which doesn't exist in the original grid, since the child node only contains 3 out of all the collumns available on the table in the sql server.
the custom form is made of a formview and sqldatasource, when i finish inserting the data, i press an update button and the window is closed while the orginal window [with the grid] get a postback.
now here is the kicker, after i select the same row again  i get the old values before the update, this happnes until i close the window and reopen the page, only then, i get the updated data.
do you have any idea why such a thing might happen ?
