I have a xamgrid with autogeneratecolumns = true. But in runtime I need to show a hyperlinkbutton instead of text based on the cell value.
Here is the code I tried:
private
void siteGrid_CellControlAttached(object sender, Infragistics.Controls.Grids.CellControlAttachedEventArgs e)
if (double.Parse(se.Latitude) > 42)
e.Cell.Control.Foreground =
new SolidColorBrush(Colors.Red);
link.Content = e.Cell.Value;
link.NavigateUri =
new Uri(http://www.google.com);
e.Cell.Control.Content = link;
e.IsDirty =
true;
When I debug it shows the cell content as hyperlink button. But in the end I see only the text in the grid. There is no link available. Could you please tell me how to achieve this?
Thanks.
The approach you're taking is going to lead to a bunch of problems, including perf issues. Is the dataType of your column a specific Type. If so, you can use our ColumnTypeMapping feature:
http://help.infragistics.com/NetAdvantage/Silverlight/2011/1/CLR4.0/?page=SL_xamGrid_Change_Column_Type_Mapping.html
If it's the same Type as other columns which should be TextColumns, then you have 2 options.
1. Manually specify your columns in xaml or in the code behind.
2. Create a custom column, that generates a TextBlock or Hyperlink based on your criteria. Then you'd use the columnTypeMapping feature to point to your column for that specific type.
-SteveZ
Here is my recent observation:
The initial load didn't show any links. But when I scroll down I'm able to see some links. If I scroll up now I see the links in the first page also. But it's very random. It's not happening for all the rows that met the condition. For few rows I see the link. Could anyone please point out what I'm missing here?
