We were testing our solution that controls the classic Infragistics ASP.NET Controls with Firefox 10. It seems that they are not compatible with Firefox 10. Are there plans on making them compatible with Firefox 10?
Norman
The classic UltraWebToolbar is having same error as WebCombo (i have version 8.3). My friend tell me : the problem lies in the code developer extract the major and minor version from Page.Request.Browser.version
string version = this.Page.Request.Browser.Version; int num = Convert.ToInt32(version.Substring(0, 1)); int num2 = Convert.ToInt32(version.Substring(2, 1));
So with Firefox 10 with version string like 10.010.0 , version.Substring(2, 1) = '.' will cause the error
[FormatException: Input string was not in a correct format.] :(
we are facing the same problem!
When will there be a hotfix available? This is rather urgent!
Regards
The version utility does not offer the option to upgrade to 11.1, it only offers 11.2.
Anyone have any ideas on how to go from 10.3 to 11.1?
Hello elPlato79,
That is because you have probably downloaded Version Utility for 11.2. In order to use Version Utility for 11.1 you should install 11.1 product first.
You can also upgrade your project manually by replacing the 10.3 assemblies and references with 11.1 ones.
Right now there are plans for creation of Untested Build addressing this issue for version 10.3 also, that is why you can wait for this build too.
Hello All,
The reported issue was researched and addressed from our R&D team and it is resolved in our latest service release for ASP.NET.
You can see our latest service releases in our web site - “Support > Service Releases” and download them from “My IG > My Keys and Downloads” page.
If you cannot see/download our latest service release you may need to register your product key first. You can register your product key in “Support > Register Your Product” page.
Thank you for your patience.
my investigation proves that infragistics controls are unable to retrieve the version number details from request object for FF 10 and above to resolve this issue please mention the target browser hint when ever use an infragistics control like weblistbar or webcombo. adding following attribute may resolve this issue.
BrowserTarget="UpLevel"
Hi Pro's of Mozilla bugs Fixer's My problem is i cannot open my Web Application in mozilla latest browser 18.0.2 whcih works fine in Mozilla 9.0.1 ... i dont know how to fix ... I tried my max and now i bugged up solving that issue .... please get me out of this big issue...Coming to my issue : I am using Infragistics grid view controls on which page i am getting error's ... i think it might be because of Infragistics Grid views.I am getting an error saying ::::Input string was not in a correct format.Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.FormatException: Input string was not in a correct format.Source Error:An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.Stack Trace:[FormatException: Input string was not in a correct format.]System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) +9591147System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +119System.Convert.ToInt32(String value) +48Infragistics.WebUI.UltraWebListbar.UltraWebListbar.getRenderer() +243Infragistics.WebUI.UltraWebListbar.UltraWebListbar.get_IsAppStyling() +28Infragistics.WebUI.UltraWebListbar.UltraWebListbar.OnPreRender(EventArgs e) +72System.Web.UI.Control.PreRenderRecursiveInternal() +103System.Web.UI.Control.PreRenderRecursiveInternal() +175System.Web.UI.Control.PreRenderRecursiveInternal() +175System.Web.UI.Control.PreRenderRecursiveInternal() +175System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2496Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
