1310
How to get the selected Cell?
Hello!
I am trying to know which is the cell that has been changed. I have binded a class that will populate each row at once. Each column is a grouped Column that has two columns inside:
Example:
Column1: January
"SubColumns of January": Money Expended | Money Earned
Column2: February
"SubColumns of February": Money Expended | Money Earned
and so on...
I have binded my xamGrid active item to my ViewModel SelectedItem
ActiveItem="{Binding SelectedItem,Mode=TwoWay}"
but I get all the row back in my selectedItem. I can't know the cell that has been
edited. Even If I put a Tag in each column, I get the event in my code behind,
the data in my sender argument that has a Tag property is shown as null.
So, any other way of knowing which cell has been changed?
Thank you
  • 1310
    Verified Answer
    Found a way, even if I continue thinking that there is a bug here... Anyway, in any eventHandler we can go through the grid and we will get a Tag with the real value in the Active Cell.
    I mean there is a bug with this, because in the args of any activeCell eventHandler, the tag and everything that is accessible is null or empty.
    var a = sender as Infragistics.Controls.Grids.XamGrid;
    var b = a.ActiveCell.Column.Tag;
