120
xamdatachart crosshair
So I am trying to work through the examples in the Infragistics.Samples.SL particularly the ChartCrossHair sample.
I pull the code to another solution and can't seem to get the cross hair to show.  The code is pretty much
the same, just pulled out to a different solution. I'm sure I'm making a simple
error but can't seem to get the cross hair to show.  I have included my xaml below.  Can someone help ?  Thanks
<UserControl x:Class="CrossHair.MainPage"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
mc:Ignorable="d"
d:DesignHeight="300" d:DesignWidth="400"
xmlns:ig="http://schemas.infragistics.com/xaml"
xmlns:models="clr-namespace:CrossHair.Models;assembly=CrossHair">
<UserControl.Resources>
       <models:NumericDataModel x:Key="randomData1" d:IsDataSource="True" />
       <models:NumericDataModel x:Key="randomData2" d:IsDataSource="True" />
   </UserControl.Resources>
<Grid x:Name="LayoutRoot" Background="White">
       <Grid.RowDefinitions>
           <RowDefinition Height="1*" />
</Grid.RowDefinitions>
<ig:XamDataChart Name="xamDataChart1" Grid.Row="0"
                     CrosshairVisibility="Visible"
                       DataContext="{Binding Source={StaticResource randomData1}}" >
<!--#BEGIN SNIPPET#-->
<!-- Notice that this Crosshair behavior is implemented locally and you will need to copy it
            if you want to show only vertical or horizontal crosshairs otherwise both crosshairs will be displayed -->
<!--#END SNIPPET#-->
<ig:XamDataChart.Axes>
<ig:CategoryXAxis x:Name="xAxis" ItemsSource="{Binding Data}">
<ig:CategoryXAxis.LabelSettings>
<ig:AxisLabelSettings Visibility="Collapsed" />
</ig:CategoryXAxis.LabelSettings>
</ig:CategoryXAxis>
<ig:NumericYAxis x:Name="yAxis" >
<ig:NumericYAxis.LabelSettings >
</ig:NumericYAxis.LabelSettings>
</ig:NumericYAxis>
</ig:XamDataChart.Axes>
<ig:XamDataChart.Series>
<ig:LineSeries ItemsSource="{Binding Data}"
Brush="Blue"
MarkerType="None"
XAxis="{Binding ElementName=xAxis}"
YAxis="{Binding ElementName=yAxis}"
ValueMemberPath="Y" />
</ig:XamDataChart.Series>
</ig:XamDataChart>
<ig:XamDataChart Name="xamDataChart2" Grid.Row="1"
DataContext="{Binding Source={StaticResource randomData2}}"
CrosshairVisibility="Visible" >
<ig:CategoryXAxis x:Name="xAxis2" ItemsSource="{Binding Data}">
</ig:CategoryXAxis>
<ig:NumericYAxis x:Name="yAxis2" >
</ig:NumericYAxis>
Brush="Red"
MarkerType="None"
XAxis="{Binding ElementName=xAxis2}"
YAxis="{Binding ElementName=yAxis2}"
</ig:XamDataChart>
</Grid>
</UserControl>
