I have bunch of surface elements that represent pieces of property on a xamMap. They are all right next to each other, so I set the stroke on the maplayer to white to create a white border. It looks great until I zoom in. Then the white borders become smaller and finally disappear if I zoom in far enough. It looks like one big red shape. Is there a way to stop this from happening?
Our development team reviewed this issue for you and stated that this rendering issue is a Silverlight limitation. Silverlight is not able to scale certain types of shapes (e.g. clipped/complex polygons) to those kinds of sizes without graphical corruption. It is allowed for the scale to be set this high for tile imagery and simple rendering purposes.
Thank you for the provided details. I have logged this behavior with our developers in our tracking system, with an issue ID of 150120 and the following case was created for you: CAS-122173-F3R3B5. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I am using the SqlShapeReader, not a shapefile. Also, It happens at a zoom level of around 30 and all of the white borders are gone before a zoom level of 40. It doesn't appear to be happening in WPF, only Silverlight.
Thank you for posting!
I have been looking into your desciption and I am not completely sure whether you are using shape files. Please note that there is a limitation if you are using shape files that allows zoom levels up to ~40 in Silverlight and ~56 in WPF applications. Does this occur when using shape files and zoom level is bigger the 40?
