I am using Ultrawebtab version v8.2. I am adding tabs dynamically which contains the pdf files.Also i am using the jquery dialogbox as messagebox.So When i click on button and tab in ultraweb contains the pdf file the messagebox hides behind pdf.So i decided to hide the ultrawebtab control when meesagebox is shown.I used following script to show messagebox and hide ultrawebtab control.
function informationDialog(title, dialogText) { var myUltraWebTab = igtab_getTabById('tabControl'); if (myUltraWebTab != null) { myUltraWebTab.element.style.display = "none"; } $('body').append("<div id='dia' title='" + title + "'>" + dialogText + "</div>"); $("#dia").dialog({ resizable: false, modal: true, close: function (event, ui) { $('body').find('#dia').remove(); }, buttons: { "Ok": function () { $(this).dialog('close'); var tab = myUltraWebTab.getSelectedTab(); // reference to div which contains all child controls of tab var div = tab.elemDiv; myUltraWebTab.element.style.display = "block"; } } });
When i click on ok button in messagebox it shows the ultrawebtab.but its height is changed.as shown in image.Before displaying message box pdf spans upto height of the page
<asp:UpdatePanel ID="UpdatePanel2" runat="server" UpdateMode="Conditional" RenderMode="Inline"> <ContentTemplate> <asp:Panel ID="Panel1" runat="server" Height="100%" Style="z-index: 0;" Visible="true"> <igtab:UltraWebTab ID="tabControl" Font-Bold="false" BorderStyle="None" runat="server" Style="border-spacing: 0px; height: 100%" AutoPostBack="true" ViewStateMode="Enabled" DisplayMode="Scrollable" LoadAllTargetUrls="false" EnableAppStyling="True" EnableTheming="true" Height="100%" EnableViewState="true" AsyncMode="On" OnTabClick="tabControl_TabClick " ThreeDEffect="false" Width="100%" SelectedTab="-1" Visible="false" ClientIDMode="Static" BrowserTarget="Auto"> <RoundedImage FillStyle="LeftMergedWithCenter" NormalImage="imageedit_2_2287647459.jpg" SelectedImage="imageedit_13_4149283003.jpg" HoverImage="imageedit_16_3964612111.jpg" /> <ScrollButtons LeftButton-Image="prev_up_new.gif" LeftButton-DisabledImage="prev_disabled_new.gif" LeftButton-HoverImage="prev_hover_new.gif" LeftButton-PressedImage="prev_down_new.gif"> </ScrollButtons> <ScrollButtons RightButton-Image="next_up_new.gif" ShowPartialTabs="true" AllowScrollToLastTab="true" UseBrowserDefaults="true" RightButton-DisabledImage="next_disabled_new.gif" RightButton-HoverImage="next_hover_new.gif" RightButton-PressedImage="next_down_new.gif"> </ScrollButtons> <AsyncOptions EnableProgressIndicator="true" Triggers="SelectedTabChanged" RequestContext="IncludeFormData" ResponseContext="IncludeAllTabs" /> </igtab:UltraWebTab> </asp:Panel> </ContentTemplate> <Triggers> <asp:AsyncPostBackTrigger ControlID="tabControl" EventName="TabClick" /> </Triggers> </asp:UpdatePanel>
Hi Prajakta,
I am continuing to follow this thread. Please let me know if you need any additional assistance regarding this.
Got it. The reason this is not working is that the 8.2 controls completed receiving services releases a long while before IE11 was released. To have support with IE11 you will need to be using the NetAdvantage 2013 vol 1 (or more recent).
My best recommendation is to update your Infragistics product version and by way of this, you will need to migrate to the aikido (ajax) control set and begin using the WebGrid.
Please let me know if you need any additional information regarding this.
This issue occurs in Internet Explorer version 11 and Mozilla firefox version 16.
I have seen the source the table igtabtabControl contains 2 row but second (the last row) doesnt span to remaining height of table and if i change the height of tabControl_cp to 500px element height increases.but height of element is already specified as 100%.
Is there any way to resolve this??
I see you are using a older version if the IG control set with 8.2. Can you tell me the browser and version of the browser you are seeing this occur with?
As a note 8.2 on thru 11.1 are now fully retired product versions. It is recommended to update to the Aikido (ajax) WebTab with the Infragistics 12.2 (or more recent) product version, as this will provide for support with the most recent releases of the browsers that you may want.
Thanks!
