165
Error on running Infragistics Sample project on RFT
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
I just installed the trial version of “Test Advantage for Windows Forms (IBM)” and am trying to run the sample project on Rational Functional Tester (Version 7.0.1.1). On playback on RFT, I see the error below:
exception_name = com.rational.test.ft.script.RunException
exception_message = Error launching [C:\Documents and Settings\All Users\Documents\Infragistics\TestAdvantage for Windows Forms (IBM) 2008 Vol. 3 CLR 2.0\Samples\TestApplication\bin\Collapsible Navigation Pane CS.exe] in working directory [C:\Documents and Settings\All Users\Documents\Infragistics\TestAdvantage for Windows Forms (IBM) 2008 Vol. 3 CLR 2.0\Samples\TestApplication\bin\]: %1 is not a valid Win32 application.
script_name = MainScript
script_id = MainScript.java
line_number = 43
exception_stack = at com.rational.test.ft.script.ScriptUtilities.run(ScriptUtilities.java:123)
at com.rational.test.ft.script.ScriptUtilities.run(ScriptUtilities.java:74)
at com.rational.test.ft.script.RationalTestScript.run(RationalTestScript.java:2814)
at MainScript.myCallScript(MainScript.java:43)
at MainScript.testMain(MainScript.java:52)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Anything I’m missing here?
