Hi All,I am facing an issue, I have two versions of same application- 1.2 & 1.3.1.2 & 1.3 do not have any GUI changes.I have recorded scripts for 1.2 & now trying to use it for 1.3.I have changed the script & called the application 1.3 over there. Application opens but then no object is recognized.I cross checked it by creation two different scripts for 1.2 & 1.3 resp. When checked the object map properties, they are identically same.Still it gives me error saying object not found.Please suggest.Thanking you in anticipation.Saurabh.
Saurabh,
Did you check with the developer if both versions of the application use the same version of NetAdvantage?
I think the best way to work on this issue is to contact Infragistics Developer support. They should be able to debug this issue and help you get going in testing your application.
Ammar
Hi Ammar,
There are some code changes, but no GUI changes.
I tried few things -
1. Created a simple script on both the versions(Scr1 & Scr2 for ver1 & ver2 resp).
2. Changed the name of the application in scr1 to ver2.
3. Used object map of Ver2 on script scr1, result it does not work.
4. Changed the name of the app in scr1 again to ver1.
5. Now it works besides the fact that it its till using object map of ver2.
I am seriously puzzled and don't know what to do....
Please help.
Saurabh.
Hi Saurabh,
The only reason I can think of is the the newer version of the applicatioin is using a newer version of NetAdvantage. in this case you will need to upgrade the version of TestAdvantage to match the new NetAdvantage version.
Can you check with the application developer if they are using a different version of NetAdvantage than the one usind be version 1.2 of the application.
