Hi all!
I'm having problems with the execution of a test script that uses an external dll... I follow the steps described in the following links but it did not work! =/
I looked for a solution during all day and couldn't...
Any of you could help me please? =(
http://www-01.ibm.com/support/docview.wss?rcss=faqtt_4Q09&uid=swg21303038
http://publib.boulder.ibm.com/infocenter/rfthelp/v7r0m0/index.jsp?topic=/com.ibm.rational.test.ft.doc/topics/t_adding_external_resources.html
the 2 suggestions listed on the first link usually works for me. One other thing you might try is to place your external dll in the bin folder of RFT.
What version of Visual Studio do you use? If you are using VS 2003 this might be the reason, try switching to VS 2005
Ammar
