I want to know how to maintain different versions of TestAdvantage installed (2007,2008,2009(vol.1)) using version utility.
I have a problem in selecting the versions in the version utility. I have to install only one version at a time and use the same version.
Note : Have registered licensed keys for the versions installed.
Thanks Ammar,
It worked.....
I think you have Win Vista or Win 7 with UAC (User Access Control) enabled, and that is the reason. the version utility updates configuration files for QTP that are located under "C:\Program Files" which cannot be changed without Administrator permissions.
All you need to run the utility successfully is to run the tool as administrator, From the start menu instead of clicking the tool icon, Right click then choose “Run as Administrator”
Another way to work around this is to disable UAC.
Please try this out and let me know
Ammar
Hi Ammar,
when i try to change the version in the testadvantage version utility its leading to an unhandled exception below :
"Access to the path C:\Program Files\Hp Quick Test Professional\dat\SwfConfig.xml is denied."
"Continue" & "Quit"
What is the problem you've seen when trying to select different versions in the version utility?
-Ammar
