385
Problem with Drop down in grid cell
I am facing a problem with Drop down in a grid cell.
Following is the description of the problem
QTP version : 10.00
NetAdvantage version : 2010 vol2
TestAdvantage : 2010 vol2
I have a grid with 2 columns. One of the columns contain a drop down with pre populated items. This list of items is same for all the rows.
When I try to change the value of a cell, by selecting a different item from the drop down, based on some validations, a warning dialog may be displayed. User can select OK/Cancel on the warning dialog.
The code I used to simulate a grid drop down is given below
Call SwfWindow("window").SwfTable("grid").ActivateCell(rowIndex, colName)
Call SwfWindow("window").SwfTable("grid").PerformAction(gridEnterEditModeAndDropdown)
Call SwfWindow("window").SwfTable("grid").SetCellData(rowIndex, colName, value)
Call SwfWindow("window").SwfTable("grid").PerformAction(gridCloseDropdown)
Call SwfWindow("window").SwfTable("grid").PerformAction(gridExitEditMode)
This code behaves quite inconsistenlty.
If i change the value of a cell which pops up the warning dialog, this code works i.e warning dialog is shown. If I first change some rows which doesnt showup the warning dialog and later try to change some other cell to a value which popsup a warning dialog, the code doesnt work i.e the value gets changed without popping up the warning dialog.
To explain the scenario more elaborately,
Let us say I have three rows in the grid.
I want to change the values (of 2nd column) in row 1 and  2  which will not popup any warning dialog.
I want to change the value in row3 which will give a warning dialog
If I directly change the value in the 3rd row first, I get warning dialog.
If I first change rows 1 and 2 and then try to change row3 to the value which generates warning dialog , the warning dialog doesnt appear.
The code is implemented using AfterCellListCloseUp to handle the selection in the list. Can you let  me know if I am missing anything in my code.
Please let me know If any more informatjon is needed.
