170
QTP11 TA11.2 WpfComboBox("").Select
Hi
I am facing issue when i try to select a value from WpfComboBox(). QTP identifies two comboxes for one comboBox , and for one it is not working at all but for the other it is selecting the value from the dropdown but throwing the error
"Object reference not set to an instance of an object"
If i use On Error Resume next... it ignores the error and works fine. Is there any solution for that.
Another issue is, There is a WpfWindow comes when i double click a specific cell in a Grid (SwfTable("Grid1")) and in that window when i try to enter value once it work... steps are like this
Double click the specific column in grid
WpfWindow open
Enter value in WpfEdit
Save
Close
Now i have to do this for multiple cells in the grid.... so once it works fine... second time it is not entering values in the WpfEditBox when WpfWindow is open.
I execute code several times and it is working fine for one instance...
could you please help me out....
I have many other issues which i will post separately... thank you
