1805
webhtmleditor inside detailsView Not working
Hi Folks,
I was using webhtmleditor inside Ajax > TabContainer > detailsview > webhtmlEditor in my previous versions of project. but now i upgraded the framework and all its components. And i am stuck with this problem from last few days.
Webhtmleditor is not initialising inside detailsview. any ideas?
Jag
Parents
  • 28464
    Hello Jag,
    It is hard to tell without seeing the ASPX / code-behind first. Are you getting any specific Javascript error? Which version of the AJAX control toolkit are you using (I assume TabContainer is from there).
    By the way, I digress, but just a suggestion - is it possible for you to use our own TabStrip component? Maybe this will lead to better results? Also, switiching between different AJAX containers like UpdatePanel and our own WebAsyncRefreshPanel (WARP) may lead to better results.
    Still, these are just suggestions. If you paste the complete ASPX so we can reproduce the problem, we will surely be able to provide additional clues.
Reply Children
No Data
