hello
I am using WebDialogWindow with update panel.if i refresh the page ,the WebImageButton inside the updatepanel is not working.what is the reason
HI,
I can't reproduce your issue.
I created sample application wiith a UpdatePanel with a ImageButton and Label inside. I also dropped a WDW onto the form. Upon Asycn Refresh caused by the ImageButton, the ImageButton kept functioning.
Here is my code behind:
using System;using System.Data;using System.Configuration;using System.Web;using System.Web.Security;using System.Web.UI;using System.Web.UI.WebControls;using System.Web.UI.WebControls.WebParts;using System.Web.UI.HtmlControls;
public partial class _Default : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) {
} protected void WebImageButton1_Click(object sender, Infragistics.WebUI.WebDataInput.ButtonEventArgs e) { Label1.Text = DateTime.Now.ToLongTimeString(); }}
Here is my Aspx page:
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
<%@ Register Assembly="Infragistics2.WebUI.WebDataInput.v8.3, Version=8.3.20083.2039, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.WebDataInput" TagPrefix="igtxt" %><%@ Register Assembly="Infragistics2.Web.v8.3, Version=8.3.20083.2039, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title>Untitled Page</title></head><body> <form id="form1" runat="server"> <asp:ScriptManager ID="ScriptManager1" runat="server" /> <div> <asp:UpdatePanel ID="UpdatePanel1" runat="server"> <ContentTemplate> <igtxt:WebImageButton ID="WebImageButton1" runat="server" OnClick="WebImageButton1_Click"> </igtxt:WebImageButton> <asp:Label ID="Label1" runat="server" Text="Label"></asp:Label> </ContentTemplate> </asp:UpdatePanel> <ig:WebDialogWindow ID="WebDialogWindow1" runat="server" Height="300px" Width="400px"> </ig:WebDialogWindow> </div> </form></body></html>
