Hi I am testing the Infragestic Webschdular from Samples adding appointments.
But not able to figure it out that where is my Data storing i already check Webschdule.MDB and found only structure but no Data which i Entered.
I want to Check what Data is Going to Which table and how it is Stored.
I want to Check Webschdule.MDB or Sql with the Data i Entered in AppointemnetADD .aspx in Tabbed pageSample..
Can Someone Help me.
Yashkant
HI,
There is a property off of the WebScheduleInfo called EnabledRecurringActivities - set it to true.
Here is a help link to that property:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR2.0/html/Infragistics2.WebUI.WebSchedule.v8.3~Infragistics.WebUI.WebSchedule.WebScheduleInfo~EnableRecurringActivities.html
Here is a help link to the WebScheduleInfo Class members.
Hi
After Doing This Recurrence Tab is not Showing in AppointementAdd Dialog I need to Check Recurrence and Varience Data Only.
why don't you create your own smaller sample webschedule website and use the webschedule access database
here is a help link on howhttp://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR2.0/html/WebSchedule_Getting_Started_with_WebSchedule_Controls_and_Components.html
Then on another page - drop a few webgrid controls on to the form and bind them to our webschedule databases. This will allow you to easily see our data.
