I'm trying to export a lot of data into Excel, but on the 'save' command, I get always an outofmemory problem.
Does somebody has an idea how to solve this issue?
Here is some sample code (Visual Studio 2008, with the Excel component 9.2) :
Dim workbook As New Infragistics.Excel.Workbook(Infragistics.Excel.WorkbookFormat.Excel2007)
workbook.SaveExternalLinkedValues = False
workbook.CalculationMode = Infragistics.Excel.CalculationMode.Manual
workbook.RecalculateBeforeSave = True
Dim wks As Infragistics.Excel.Worksheet = Nothing
Dim SheetRow As Integer = 1
Dim RowsCount As Integer = 0
Dim wksRow As Infragistics.Excel.WorksheetRow
wks = workbook.Worksheets.Add("Sheet" & SheetRow)
With wks
For rowi As Long = 1 To 100000
RowsCount += 1
wksRow = wks.Rows(rowi)
With wksRow
For i As Integer = 1 To 50
.Cells(i).Value = "VAL"
Next
End With
wks = Nothing
workbook.Save("c:\abc11.xlsx") '-Out Of memory exception!!!
I'm using the Infragistics2.Excel.v8.3 version 8.3.20083.1009 and I'm getting this error. Is this the version that fixed this issue? Is there an update or service pack available for download?
In addition, how can see the issue id information?
This was fixed (issue id 21642) in versions 8.3 and up. Try upgrading to the latest SR to fix this issue.
