After upgrading to 2010.2.20102.2091 the ultragauge doesn't display well and can´t find why.
I attach a printscreen of the gauge I get and paste a copy of the gauge preset.
Thanks in advance for any suggestion.
<?xml version="1.0" encoding="utf-8"?><!--<PresetInfo PresetName="gauge" PresetDescription="elgauge" PresetType="All" />--><igGauge:UltraGauge BitMapSize="174, 174" BackColor="#F5FFFA" ToolTip="Margen Bruto - ARGENTINA"> <Gauges> <igGaugeProp:RadialGauge Bounds="14, 26, 145, 145" MarginString="2, 2, 2, 2, Pixels" Key="radial"> <Dial> <BrushElements> <igGaugeProp:MultiStopRadialGradientBrushElement> <ColorStops> <igGaugeProp:ColorStop Color="161, 161, 161" /> <igGaugeProp:ColorStop Color="96, 96, 96" /> <igGaugeProp:ColorStop Color="89, 89, 89" /> </ColorStops> </igGaugeProp:MultiStopRadialGradientBrushElement> </BrushElements> <StrokeElement Color="Navy"> <BrushElements /> </StrokeElement> </Dial> <Scales> <igGaugeProp:RadialGaugeScale StartAngle="110" EndAngle="430"> <MajorTickmarks Frequency="509383.34097903094" StartExtent="85"> <BrushElements> <igGaugeProp:SolidFillBrushElement Color="Black" /> </BrushElements> </MajorTickmarks> <MinorTickmarks Frequency="50938.334097903091" StartExtent="100" EndExtent="95"> <BrushElements> <igGaugeProp:SolidFillBrushElement Color="Black" /> </BrushElements> </MinorTickmarks> <Labels Orientation="Horizontal" Frequency="509383.34097903094" Extent="65" EqualFontScaling="True" Font="Tahoma, 5pt"> <BrushElements> <igGaugeProp:SolidFillBrushElement Color="White" /> </BrushElements> </Labels> <Markers> <igGaugeProp:RadialGaugeNeedle StartExtent="-20" MidExtent="0" EndExtent="65" StartWidth="5" MidWidth="3" EndWidth="1" WidthMeasure="Percent" ValueString="17000000" PrecisionString="1"> <Anchor RadiusMeasure="Percent"> <BrushElements> <igGaugeProp:SimpleGradientBrushElement GradientStyle="BackwardDiagonal" StartColor="Gainsboro" EndColor="64, 64, 64" /> </BrushElements> <StrokeElement> <BrushElements> <igGaugeProp:RadialGradientBrushElement CenterColor="Gray" SurroundColor="WhiteSmoke" /> </BrushElements> </StrokeElement> </Anchor> <StrokeElement Thickness="0" Color="255, 197, 204"> <BrushElements /> </StrokeElement> <BrushElements> <igGaugeProp:SolidFillBrushElement Color="255, 197, 104" /> </BrushElements> </igGaugeProp:RadialGaugeNeedle> <igGaugeProp:RadialGaugeNeedle StartExtent="-20" MidExtent="0" EndExtent="65" StartWidth="5" MidWidth="3" EndWidth="1" WidthMeasure="Percent" ValueString="13404824,7626061" PrecisionString="1"> <Anchor RadiusMeasure="Percent"> <BrushElements> <igGaugeProp:SimpleGradientBrushElement GradientStyle="BackwardDiagonal" StartColor="Gainsboro" EndColor="64, 64, 64" /> </BrushElements> <StrokeElement> <BrushElements> <igGaugeProp:RadialGradientBrushElement CenterColor="Gray" SurroundColor="WhiteSmoke" /> </BrushElements> </StrokeElement> </Anchor> <StrokeElement Thickness="0" Color="0, 0, 0, 100"> <BrushElements /> </StrokeElement> <BrushElements> <igGaugeProp:SolidFillBrushElement Color="0, 0, 0, 0" /> </BrushElements> </igGaugeProp:RadialGaugeNeedle> </Markers> <Ranges> <igGaugeProp:RadialGaugeRange StartValueString="9651473,82907638" EndValueString="10723859,8100849"> <BrushElements> <igGaugeProp:SimpleGradientBrushElement GradientStyle="BackwardDiagonal" StartColor="255, 0, 200" EndColor="255, 0, 0" /> </BrushElements> </igGaugeProp:RadialGaugeRange> <igGaugeProp:RadialGaugeRange StartValueString="10723859,8100849" EndValueString="12064342,2863455"> <BrushElements> <igGaugeProp:SimpleGradientBrushElement GradientStyle="BackwardDiagonal" StartColor="255, 255, 200" EndColor="255, 255, 0" /> </BrushElements> </igGaugeProp:RadialGaugeRange> <igGaugeProp:RadialGaugeRange StartValueString="12064342,2863455" EndValueString="14745307,2388667"> <BrushElements> <igGaugeProp:SimpleGradientBrushElement GradientStyle="BackwardDiagonal" StartColor="0, 128, 200" EndColor="0, 128, 0" /> </BrushElements> </igGaugeProp:RadialGaugeRange> </Ranges> <BrushElements /> <Axes> <igGaugeProp:NumericAxis StartValue="9651473.8290763758" EndValue="14745307.238866685" /> </Axes> </igGaugeProp:RadialGaugeScale> </Scales> <Annotations> <igGaugeProp:BoxAnnotation> <Label FormatString="Margen Bruto - ARGENTINA" Font="Tahoma, 8pt"> <BrushElements> <igGaugeProp:SolidFillBrushElement Color="255, 255, 255" /> </BrushElements> </Label> <BrushElements> <igGaugeProp:SolidFillBrushElement Color="0, 175, 0" /> </BrushElements> </igGaugeProp:BoxAnnotation> </Annotations> <BrushElements /> </igGaugeProp:RadialGauge> </Gauges> <Effects /> <Annotations /></igGauge:UltraGauge>
Thank you for your interest in our issue. We appreciate a quick resolution.
I created a private case and linked it to a development issue. You will be notified automatically when a resolution is found.
Magued
I am able to reproduce the issue when setting Formats set to Spanish(Uruguay). We are working on a resolution.
I am still struggling with this issue.
In fact I don't have much idea where to look at... I suspect it has something to do with culture info but without much proof of it... I already mentioned it but I am using Windows 7 Ultimate with Formats set to Spanish(Uruguay) and tried with DisplayLanguage set to English and to Spanish... System.Threading.Thread.CurrentThread.CurrentCulture is {es-UY} at the time I save or load the gauge preset.
Have you been able to run the sample under this configuration?
If you discard a culture info issue, what would you suggest as the next step?
Thanks.
I am following up with you and if the issue is resolved.
