65
How to use WebDocumentExporter Custom Exportmode?
How can I do that if I want to export a WebDataGrid to a custom stream or location? It seems to me with version 10.3 there is no way to do it using WebDocumentExporter.
Parents
  • 3147
    Suggested Answer
    First you have to set the ExportMode to Custom:
    <ig:WebDocumentExporter ID="WebDocumentExporter1" runat="server" ExportMode="Custom">
    </ig:WebDocumentExporter>
    Then you can modify the following code to meet your requirements:
     protected void btnExportPDF_Click(object sender, EventArgs e)
      Report report = new Report();
      WebDocumentExporter1.Export(WebDataGrid1, report);
      // Create whatever stream you need.
      MemoryStream stream = new MemoryStream();
      report.Publish(stream, FileFormat.PDF);
      HttpResponse response = HttpContext.Current.Response;
      response.Clear();
      response.AddHeader("content-disposition", "attachment; filename=report.pdf");
      response.ContentType = "application/pdf";
      response.Buffer = true;
      response.BinaryWrite(stream.ToArray());
      response.Flush();
      response.End();
Reply Children
No Data
