The webdropdown is losing my selected item after I click on a webimagebutton. It's reverting back to the first item in the list. Anyone else had this problem?
ET
It happens to me after I set the autopostback to true, even with EnableAjaxViewState="true". I use NetAdvantage 2012.
Hi all,
It has been some time since your posts, however in case you still need assistance I would be glad to help.
I am so far unable to replicate the described behavior using version 11.2.20112.1019 of .NetAdvantage. Because the matter seems to be isolated to specific projects, in order to continue my research on the matter I would need a small sample illustrating the issue.
Please do not hesitate to contact me if you have any questions.
I still have the data...I just lose me selection. I have other projects where it works OK, but I can't find any differences in the webform or the web.config.
I have a similar issue. I'm trying to use it in an UltraWebGrid. When I add a new row the prior row has the first item selected and when clicking on the dropdown arrow, there is no data in the dropdown.
