I'm using NetAdvantage 2008 Vol 1 and I'm having a problem with scrollbars appearing in the browser when I add a UltraChart and move my mouse over it.
Example code:
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
</head>
<body>
<form id="form1" runat="server">
<div>
<igchart:UltraChart ID="UltraChart1" runat="server">
</igchart:UltraChart>
</div>
</body>
</html>
I have no code-behind, no css, no data being bound to the chart, so all you get is the default image saying "data not available", but it demonstrates the problem.
If you create a page as above (I'm using Visual Studio 2005 SP1) and run it, and then resize your browser as small as possible without scrollbars appearing, and then put your mouse over the image... scrollbars appear... why?
Any ideas?
I managed to fix the issue by creating a javascript proxy function to wrap around the ShowToolTop, HideToolTip and onmousemove client script methods.
The main chunk of the problem is because they have used the visibility='hidden' css property to hide the tooltip instead of display='none'.
I've also made it so the tooltip will appear to the left of the mouse if it detects that it's going to fall off the right hand side of the page and cause the scroll bars to appear. This might need to be adapted if you want it to happen against the right edge of a different element.
The charts ClientID is used as the name of the javascript object which represents each instance of the chart and is accessible as a global variable once the page has finnished loading.
I've used jquery here but this can easily be adapted to another library or plain old javascript.
// To get the correct ClientID, this code needs to be added // from code behind and after the control has been added to the page // (js method 'fixChartTooltip()' needs to be called once for each chart on the page) $(document).ready(function(){ fixChartTooltip(" & MyChart.ClientID & ") });
// Add this to the markup or .js file function fixChartTooltip(TrendObject) { var proxyShow = TrendObject.ShowTooltip; var proxyHide = TrendObject.HideTooltip; var proxyOnMouseMove = TrendObject.onmousemove; TrendObject.ShowTooltip = function(evt, id, args){ proxyShow.apply(this,[evt, id, args]); $('#' + this.ID + '_IGTooltipBody').css('display','inline'); ensureTooltipVisible.apply(this); }; TrendObject.HideTooltip = function(evt, id, args){ proxyHide.apply(this,[evt, id, args]); $('#' + this.ID + '_IGTooltipBody').css('display','none'); }; TrendObject.onmousemove = function(evt, id){ proxyOnMouseMove.apply(this,[evt, id]); ensureTooltipVisible.apply(this); }; function ensureTooltipVisible() { var tooltip_ref_body = $('#' + this.ID + '_IGTooltipBody'); var width = tooltip_ref_body.width(); var leftEdge = tooltip_ref_body.position().left; var rightEdge = leftEdge + width; if (rightEdge > $(window).width()) { tooltip_ref_body.css('left',leftEdge - width + 'px'); } } }
Is this issue resolved, or still persists, even am also facing the same problem. sometimes scroll bars will go crazy way bcz of this tool tip. Is there any work around or its a problem with the Infragisitics development??? please let me know... how can i solve this problem.
If I set JavaScriptEnabled=false, the problem goes away, but then so do the tooltips
sorry, it's just not happening on my side, so i don't know what's up. does it happen when JavaScriptEnabled = false on the chart?
maybe you could provide a video or a screenshot or something? or contact our support department, as they might do a better job of reproducing / understanding the problem.
I'm using IE7, though it also does it in Firefox 2. I've tried setting Tooltips.Overflow property to ChartArea and ClientArea and it made no difference.
