3475
UnboundCheckBoxField displaying black block instead of unchecked appearance
Infragistics4.Web.v11.1, Version=11.1.20111.1006
MS .NET Frameword Version 4.0.30319 SP1Rel
In my parent of the WHDG there is a UnboundCheckBoxField in the first column.  This checkbox is used to delete the associated data in the row when the Save button is selected.  This is done by posting back to the server, using SQL to get the data, put it in a DataSet and bind the DataSet to the WHDG. This all works as expected except the UnboundCheckBoxField.  When the page refreshes, the UnboundCheckBoxField is filled in (a black square) instead of the unchecked state.  I have tried all the following in the code behind, before binding the new DataSet, without luck.  What is going on with this?
whdgOrganize.Rows.Clear()
whdgOrganize.ClearTemplates()
whdgOrganize.GridView.ClearTemplates()
whdgOrganize.GridView.Rows.Clear()
whdgOrganize.GridView.ClearDataSource()
HTML: <ig:UnboundCheckBoxField Key="RemoveDocument" Header-Text="Rem" Width="30px"> </ig:UnboundCheckBoxField>
