210
Load on demand issue when datatree part of separate dll
Hi Guys,
I have an issue with Load on demand. I have two projects. One is Web Project and one Library project where i'm adding WebDataTree (and use it as dll refernece i Web Project).
Definition on data tree is:
InnerTree = New WebDataTree()
        InnerTree.ID = Me.UniqueID
        InnerTree.DragDropSettings.DragDropMode = DragDropMode.Copy
        InnerTree.DragDropSettings.EnableDragDrop = True
        InnerTree.DragDropSettings.AllowDrop = False
        InnerTree.ClientEvents.DragEnter = "InnerTree_DragEnter"
        InnerTree.ClientEvents.NodeDropping = "InnerTree_DragEnter"
        InnerTree.EnableAjax = True
        InnerTree.EnableAjaxViewState = True
        InnerTree.EnableViewState = True
        InnerTree.InitialExpandDepth = 1
        InnerTree.InitialDataBindDepth = 1
        InnerTree.EnableConnectorLines = True
Unfortunately after postback i receive bad response from server here in js code:
/******************************************Callback Request Handler*********************************/
$IG.CallbackRequestHandler = function (manager, callbackObject, async)
try
obj = Sys.Serialization.JavaScriptSerializer.deserialize(response)
catch (e)
/* OK 2/7/2011 63320 - if a website times out and the framework re-directs the user to the login page
we should not process the response, but instead just display the login page  */
if (response.indexOf("[") != 0 && (response.indexOf("<HTML") > -1 || response.indexOf("<html") > -1))
document.write(response); //call stack is showing that this line is executed
return;
failed = true;
me._manager._requestFailed(me, me._callbackObject, false, "Deserialization failure: Invalid response.");
It seems that reponse contains whole definition of page (like
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">....)
instead of json definition of tree. I suppose that it is because definition of data tree is in seperate dll and request is not handled properly.
Maybe i should manually add some input in config or handle this request diffrently.
We are using:
Infragistics4.Web.v11.1
11.1.20111.1006
Any suggestions.
