240
How to bind to DataTable.Column.Caption instead of DataTable.Column.ColumnName?
DataTable dt = new DataTable();
dt.Columns.Add("col1").Caption = "column one";
dt.Columns.Add("col2").Caption = "column two";
dt.Columns.Add("col3").Caption = "column three";
dt.Rows.Add("val11", "val12", "val13");
dt.Rows.Add("val21", "val22", "val23");
DataView dv = new DataView(dt);
WebDataGrid1.DataSource = dv;
WebHierarchicalDataGrid1.DataSource = dv;
After performing this code you will see WebDataGrid with Captions from DataTable (dt)
And WebHierarchicalDataGrid will show ColumnNames (instead of Captions) from DataTable (dt)
Why and how to fix it?
  • 29417
    Verified Answer
    Hello arseny ,
     WebHierarchicalDataGrid should not be bound  to a non-hierarchical data source like a data table. If you want to have a WebHierarchicalDataGrid with a single level of data you can bind it to a DataSet with just one  DataTable. For example:
            DataSet set = new DataSet();
            set.Tables.Add(dt);
            WebHierarchicalDataGrid1.DataSource = set;
    You can see a list of the supported data sources for the WebHierarchicalDataGrid here: http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebHierarchicalDataGrid_Data_Binding.html
    Best Regards,
    Maya Kirova
    Developer Support Engineer II
    Infragistics, Inc.
