635
not getting Websplitter Id
 I have 3 panes in websplitter.Since my div in 3rd pane was going outside i used the initialize event for making it inside 3rd pane.now on the divarrow click i have called the JavaScript function collapse() but i am not getting splitter inside this function using $find it returns null.
function collapse() {
            var splitter = $find('<%=Splitter.ClientID%>');
                      alert(splitter);
            var pane = splitter.getPaneAt(0);
            alert(pane);
            var size = pane.get_size();
            var timer = setInterval(function () {
                size -= 20;
                pane.set_size(Math.max(10, size));
                if (size <= 10) {
                    clearInterval(timer);
                    var barFor1stPane = splitter._elements['b0'];
                    // or
                    //var barFor1stPane = $(splitter.get_element()).find("[mkr='b0']")[0];
                    barFor1stPane.style.display = 'none';
            }, 30);
    function initSplitter(splitter) {
            var tbl = splitter._elements.tbl;
            if (tbl)
                tbl.style.tableLayout = 'auto';
    <cc1:WebSplitter ID="Splitter" runat="server" BorderStyle="Solid" BorderColor="Black"
        BorderWidth="3px" ClientIDMode="Static" Style="display: block; height: 100%;
        position: absolute; visibility: visible; left: 5px; right: 100px; top: 65px;
        background-color: #F0F0F0; z-index: 999">
        <ClientEvents Initialize="intialize" />
        <Panes>
            <cc1:SplitterPane runat="server" Size="30%" ScrollBars="Hidden" Style="height: 100%"
                CollapsedDirection="None" Locked="true">
                <Template>
    <div id="test1" style="position: relative; width: 100%; height: 100%; z-index: 999">
                        <div id="header" class="x-panel-header x-unselectable" style="-moz-user-select: none;
                            overflow: visible; top: 0px;">
                            <asp:Label ID="panelheader" runat="server" Text="Object Reader" CssClass="x-panel-header-text"></asp:Label>
                            <div id="dvArrow" class="x-tool x-tool-toggle x-tool-collapse-west" onclick="collapse()">
                            </div>
                        </div>
    </div>
                </Template>
            </cc1:SplitterPane>
    <cc1:SplitterPane runat="server" Size="40%" Style="height: 100%;" CollapsedDirection="None">
                <Template>
</Template>
            </cc1:SplitterPane>
    <cc1:SplitterPane runat="server" Size="30%" CollapsedDirection="None" Locked="true"
                Style="height: 100%">
                <Template>
<div></div>
</Template>
            </cc1:SplitterPane
