Hi please check the image attached and help me to understand why the spell checker is underlining parts of two different word for bad words.
In text box control, it under line work "coninue" but in spell checker popup it under line half of "coninue" and half of next word.
And i can not change or upgrade the Webspellchecker dll with upgraded version.
singh
Hi singh,
Thank you for the information. After some testing, this is related to an old issue involving plus signs (+). Each time a plus is encountered while parsing, the underline is offset by two places.
I've tried to apply the bugfix in a workaround and have not been successful. You will need to upgrade in order to resolve this.
The fix is available in the latest Service Release for 10.3 (10.3.20103.2217).
If you have any further questions or concerns with this, please let me know.
1. it is version 10.3.20103.1013.
2. integrated in an web application. using IE11. window server 2008 R2.
3. it is happening with multiple words..
I am using spell checker with WebHtmlEditor control. version 10.3.20103.1013.
I am pasting full string for your check.
Hello singh,
Thank you for posting in our forums!
It is not possible to determine what is causing this with your screenshot. I would need some more information in order to better assist you with this.
Please answer my following questions:
1. What build of Infragistics 10.3 are you using? e.g. 10.3.20103.22282. What version of Windows and Internet Explorer are you using?3. Do any other words in this instance experience this issue such as "Spurlings", "visits", or any other words?
It would also help to determine what is causing this if you could provide a simple sample that demonstrates the issue.
