are there changes in behavior of AutoCompletMode.SuggestAppend between versions 14.2.20142.2010 and 14.2.20142.2168 ?
I.e. there is given a DropDownList with some countries: L, S, SK, SLO
Old version: Input keys S-L -> Suggestion (like expected) is "SLO"
Newer version: Input keys S-L -> Suggestion is "L". Pressing S three times -> result is "SLO".
Thank you for help. Regards,
Olaf
Hello Milko,
That is the point that I mistunderstood
(1) For the combination DropDownList and AutocompleteMode=Append I get my expected behavior S-L ==> SLO
(2) For the combination DropDownList and AutocompleteMode=SuggestAppend I get S-L ==> L
For case (1) I have no type-in edit window, but the search is working respecting probably the value in KeyBoardSearchInterval with the default of 1000 milliseconds.
For case (2) there seems to be no searchinterval.
For me it is O.K. to find out, that case (1) is working like the old AutoComplete = true.
Thank you for your help.
Best regards,
Hello Olaf,
Thank you for your feedback.
This is expected scenario. AutoCompleteMode is designed to match based on what is typed into the combo’s edit window. When the DropDownStyle is set to DropDownList you cannot type in the edit window and UltraComboEditor does not take into account the value of AutoCompleteMode.
Please let me know if you need any additional information.
your example is working like expected. But in my example there is Me.UltraComboEditor1.DropDownStyle = Infragistics.Win.DropDownStyle.DropDownList. If I set it in your program, I can reproduce 'my' described behavior.
Following the steps you have described I have tried to reproduce this behavior. I have created a small sample project with one UltraComboEditor. I have added L, S, SK and SLO as editor’s items. I have set AutoCompleteMode to SuggestAppend. When I enter SL in the editor it displays SLO and when I enter SSS nothing is shown in the editor.
In the attached archive I am sending you the sample I have tested with. Please check my sample and let me know if you experiencing the same behavior.
Please, if my sample does not show correctly the logic you are implementing fill free to modify it and send it back to me, or if you have a sample of your own demonstrating this behavior please send it to me so I can investigate further this.
Looking forward to your reply.
yes, but something went wrong for me setting it to SuggestAppend like desribed in my first post:
I.e. there is given a DropDownList with some countries: L, S, SK, SLO and AutoCompleteMode = SuggestAppend.
Input keys S-L -> Display value is "L". Pressing S three times -> result is "SLO".
I expect after S and L the display value "SLO" and not "L".
With kind regards, Olaf
