I want to make my UltraMonthViewMulti rezisable, but it is important, that it keeps the number of months.
On init I have the dimension (4:3) where it displays one whole year (from Jan to Dec). When I resize the window, is it possible that the Calendar keeps the number of months? It would be okay, if the dimension changes, but not the number of months. (6:2), (12:1), (3:4) dimension would all be okay.
Thanks!
Hello Christian,
Thank you for contacting. Looking into the API of UltraMonthViewMulti I don’t see any property exposed to resize the Calendar and keeps the same numbers while you resize the window. These calendar have the fixed size.
To have this option available for future versions, you can suggest a new feature idea at : <ideas.infragistics.com>
Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
Thank you in advance to submitting your product idea.
