Is there a way to prevent the tooltip on charts from rendering incorrectly? Whenever I move the mouse over a chart, I see the tooltip appear where I move the mouse, but it doesn't clear until a second or so later. This leaves a trail of tooltips where I move the mouse.
Hello and thank you for contacting Infragistics. This appears to be the WinChart. Would you mind testing the WinPieChart/UltraPieChart. This is a more updated dedicated control for pie rendering.
eg.
https://ko.infragistics.com/help/winforms/piechart-data-binding
And whilst we're at it, is there a way to add padding around the tooltip? As you can see, the border is drawn touching the text.
