15
UltraFormattedTextEditor Text Overlap + NewLine indentation
a user discovered, that text in a new line entered after a bolded out word gets visibly indented.
If you then try to remove the (non-existing) space in front of (AH), the text will be overlapped with the line above it.
I found an old thread with a similar issue, but the user never responded: https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/53820/text-overlapping-in-ultraformattedtexteditor
We are using v21.2, I tried upgrading to v22.1, but that did not solve the issue either.
Thank you and best regards
